torrsion bars lift
No pics, but since you have a 06+ Ram you can not do it anyhow. You need a leveling kit.
If this is "a question for a friend" go about 1/2 way on your drivers door. Lay flat, slide under truck. You will see two big bolts at the end of two big bars going to the front of the truck. Turn clockwise. Also a good idea to lift the front end off the ground before doing this. I would go a trun at a time, sit it back down, and repeat. Maybe even take it for a drive in between turns as it will result in a harsher ride.
