'08 Ram 1500 4.7L engine noise
Old Oct 16, 2008 | 11:04 PM
Ben D.'s Avatar
Ben D.
08 4.7L six speed here and I run name brand 87 octane in mine and have no problems with sounds the engine makes. other than that sexy rumble of the v8
Old Dec 10, 2008 | 12:31 PM
08DodgeTRX's Avatar
08DodgeTRX
My 08 4.7 has no engine noise either, no pinging etc.
But when my Jeep 4.0 was new before the motor was broke in, it would ping under load when i should have downshifted. But it went away, weather that was because I learned to drive it better or the motor broke in, i am not sure.
Old Dec 10, 2008 | 01:14 PM
dirtydog's Avatar
dirtydog
Moderate User
Should have run it hard the first few thousand miles. ***** footing doesn't break in an engine.
Go down the parts store or Wallyworld and buy some octane booster and fill up with premium grade gasoline 91oct or better if you can. That will even up the octane for what you have in there and see if that solves your problem.
Does, the new 4.7L have mds now like the hemi's? i hope not for all those owners. It sucks
Old Dec 10, 2008 | 01:21 PM
08DodgeTRX's Avatar
08DodgeTRX
No MDS....and I'm averaging 10 Miles Per Gallon...... on Gas not E85......I'm supposed to be getting 16 average.....but I've only got 500 miles on the motor.......
man this 4.7 is a weird motor......its like driving a huge ricer b/c all the power is in the upper powerband
Old Dec 10, 2008 | 03:42 PM
TRXHemi's Avatar
TRXHemi
10mpg?? Damn - are you rompin' it every time?? Mine is not 4wd but I get around 17.5 in mixed driving. I actually got over 20 on a long trip.
Old Dec 10, 2008 | 06:38 PM
manualagain's Avatar
manualagain
2X Ben D, same drive train, never a problem, always 87 octane, why spend more when the 87 does great?
Old Dec 10, 2008 | 06:59 PM
Ben D.'s Avatar
Ben D.
i get about 15-16 mpg hand calculated in the city i rarely do highway do i can't really give an estimate on that. my guess is about 20mpg that's what the overhead says and so far my overhead is only off maybe 1 mpg in comparison to my hand calcs.
Old Dec 10, 2008 | 10:27 PM
08DodgeTRX's Avatar
08DodgeTRX
No i actually drive very conservative, but i wont lie its new and i'm getting on it every now and then, but really 2 or 3 times a tank. it not like i'm doing smoking doughnuts in the parking lot, for 20 minutes to warm it up.
Old Dec 30, 2008 | 10:29 PM
pull-up's Avatar
pull-up
*update*
After several tanks of gas from several different station and grades, I found that it only does it in 4th gear. 1, 2, 3, 5, and 6th all ok except fourth. Don't why but that more miles I put on the truck the tone of it changes. I now don't think its detonation, i thinks its the transmission that making all the noise above 2k RPM in 4th gear.
