Removing side moldings
Old Oct 21, 2008 | 10:56 AM
uspatriot's Avatar
uspatriot
Default Removing side moldings
Do you have to heat them up to remove them? Also do they leave a stick residue after you take them off? And does the paint look different underneath?
Old Oct 21, 2008 | 11:07 AM
TooFastForLove's Avatar
TooFastForLove
Myself, honestly, i just started picking at it, got an edge up and it started to come off.
Some spots got trickier, so i took a plastic drywall scraper, and wrapped a tshirt around it so it wouldnt scratch my paint. But didnt pry it off in big chunks, but worked at it a little bit at a time.
Yeah, there was some adhesive gunk left over, but i used a 3M aerosol adhesive remover, worked like magic.
Afterwards, it may take a good washing, and another once over with the 3M remover again.
my driverside door was in an accident before i bought it, and the moulding was ghetto rigged back on with silicone caulk instead of the factory 3M, so for me, it took me about 2 hours all together.
Old Oct 21, 2008 | 04:56 PM
damquick1's Avatar
damquick1
are you reffering to the side spears on th doors?
Old Oct 21, 2008 | 05:26 PM
uspatriot's Avatar
uspatriot
yea mine are discolored and i want to take them off
Old Oct 22, 2008 | 08:04 AM
uspatriot's Avatar
uspatriot
i guess you just peel them off but should i use a blow drier to heat it up?
Old Oct 22, 2008 | 08:36 AM
oefootball_70's Avatar
oefootball_70
That wouldn't hurt. They are held on the same way as the ram 1500 logo's are. So I would say a blow drier and some fishing line would work good too.
Old Oct 22, 2008 | 03:37 PM
TRXHemi's Avatar
TRXHemi
Goo-gone works as well to get the adhesive off. May have to saturate a sponge or something to really let it soak on there, but it will come off pretty easily. Just take your time.
Old Oct 23, 2008 | 01:54 AM
z3r0's Avatar
z3r0
i used fishing line and got about 4 inches back than i was able to lift up on teh spear and slowly separate it from teh truck
than i hit it with an eraser wheel and got most the stuff off
but teh worst part is i had to hand polish both sides and that took 2 hrs
