4.7 Power
If I had no limit on money I would first decide if I wanted to be Naturally Asperated or Boosted...
N/A:
Forged Crank
Forged H-BEAM SCAT RODS
FORGED ROSS 11:1CR
ALUMINUM SINGLE PLANE INTAKE MANIFOLD
212 Cams
CNC RACE PORTED HEADS
ARP HEAD STUDS
ARP BED PLATE STUDS
F&B 72MM THROTTLE BODY
SCT TUNE
DYNO JET WIDE BAND COMMANDER
VAMPIRE DIRECT IGNITION CONTROL
4.56 Gears
2800 Edge Converter
I would be willing to bet N/A this engine would be able to crank out in the ball park of 375-400RWHP.
Supercharged.... You have a few options, we currently have Adapters that will allow you to mount a Cobra Eaton M112... or a Whipple charger or Kenny Bell supercharger designed to mount to the 2003-2004 cobra. The ONLY issue you would need to address would be pulley alignment... You would need to EXTEND the pulley about one inch out.
Contact me if you have any questions... Also feel free to check out our 4.7L PERFORMANCE PAGE
SPEED SAFE, AIR RAM
N/A:
Forged Crank
FORGED ROSS 11:1CR
212 Cams
ARP HEAD STUDS
ARP BED PLATE STUDS
SCT TUNE
4.56 Gears
2800 Edge Converter
SPEED SAFE, AIR RAM
The H/O cams alone would be worth approximately 20-25RWHP. At least on my engine they where.
I really enjoyed the H/O's when I had them, I was able to run my best 60ft time of 1.99 with the H/O cams... Now with the 212 cams ported heads and SCT tune my best 60ft is 2.24... That's a bunch of time lost in the first 60ft!
With stock Compression ratios H/O cams teamed up with Ported heads would make for the best STREET/STRIP combo in my opinion.
SPEED SAFE, AIR RAM
