build sheet
Old Nov 12, 2008 | 01:14 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by lxman1
LD = Light Duty.
Mine came like this
3.92 Axle Ratio
Corporate 9.25 LD Rear Axle
Anti-Spin Differential Rear Axle
Mine says the same.
Old Nov 12, 2008 | 02:43 PM
disturbedgator's Avatar
disturbedgator
i dont see it, but here is my build sheet ....
Cloth 40/20/40 Bench Seat
Taupe
Monotone Paint
4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
136 Amp Alternator
600 Amp Maintenance Free Battery
4 Wheel Disc Rr Anti-Lock Brakes
40/20/40 Split Bench Seat
Rear Folding Seat
Front Height Adjust Shoulder Belts
Next Gen Multistage Front Air Bags**
Front Seat Area Carpet
Front Floor Mats
Passenger Assist Handle
Rear Underseat Compartment Storage
Overhead Console w/Trip Computer
All 5-Speed Automatic Transmissions
5-Spd Automatic 545RFE Transmission
Lock-Up Torque Converter
Man Shift-on-the-Fly Transfer Case
205MM HD Front Axle
3.55 Axle Ratio
All Gas Engine
4.7L V8 MPI Engine
Tinted Glass Windows
Rear Fixed Window
Rear View Auto Dim Mirror
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Air Conditioning
Dash Liner Insulation
Floor Tunnel Insulation
Route 63 - CSX, Twin Oaks, PA
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
STRIPE/BADGE/MOLDING/COLOR
Glove Box Lamp
Halogen Headlamps
Fog Lamps
Cargo Lamp
Bright Rear Bumper
Body Color Upper Fascia
Bright Front Bumper
Front License Plate Bracket
Bright Grille
Ram's Head Badge
SLT Badge
4X4 Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
Front Bumper Sight Shields
50 State Emissions
EVAP Control System
Federal Tier 2, Bin 10C Emissions
34 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Speed Control
Next Generation Engine Controller
Flame Red Clear Coat
All Radio Equipped Vehicles
AM/FM Compact Disc Radio w/Chgr Ctrl
4 Speakers
Fixed Long Mast Antenna
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
P245/70R17 BSW All Season Tires
Michelin Brand Tires
17" Steel Spare Wheel
17X8.0 Steel Chrome Clad Wheels
All Steel Wheels
Center Hub
Non Adjustable Pedals
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Manuf Statement of Origin
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
Old Nov 12, 2008 | 02:46 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, not a LS rearend. An open 3.55.
Good to see that you got 4 springs as well
Old Nov 12, 2008 | 04:28 PM
disturbedgator
not all came with four springs?
Old Nov 13, 2008 | 09:46 PM
whiteram05's Avatar
whiteram05
I just ordered my build sheet. After reading over the post giving the build sheet details, I really look forward to seeing mine!
Old Nov 14, 2008 | 10:34 PM
lxman1's Avatar
lxman1
Site Moderator
Just odd that it would list them separately. I don't think I would buy a truck if it only and with
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
And no left rear
It doesn't actually show which springs (rating)
