What are the best offroad lights
I found a set of lights that I'm gonna get. They are Brand new and have a nice price. They are PIAA's new All Terrain Pattern ATP http://www.piaa.com/Lamps/Lamp-pages/520atp.html
Hey 6 Hemi Ram I like you light set up with the day-lighters. One question that I was wondering was if those are street legal when driving at night. I wanted to do the set up with 2 in the grill and 4 over the cab like yours, but still want to be able to use them. Can I drive down the street with those and do I need a larger battery or alternator?
you can drive down the road with lights in the grill as long as they are pointing downwards I believe 1.5" every 20ft. As far as the lightbar on top, clearly you cannot drive on the road with them because you'll blind oncoming traffic.
Yeah I figured that the overheads were illegal but assumed that the grills would be fine. Is there a way to put in 2 KC daylighters (130watt) and have them hooked up to light up when I pull the light switch out for my running lights on the bumper?
as stasted above the bulkhead lights are not street legal and wont pass inspection here. i do use them though because of the deer problem and i live in the stix. the ones in the grill are legal. however, they are way too bright to leave on when oncoming traffic can be seen. im getting ready to install a foot activated highbeam switch like older vehicles used to have that operates the ones in the grill and the ones on top but also keep separate switches so i can run with upper, behind the grill or both if i want to.
oh and an answer to your other questions. when running i dont notice much difference or drain on the alternator. so no you'll be fine with both. as for hooking into your lights, of course. there is always a way. you willl run the wire that activates the relay for the big lights to the power wire that turns on what ever lights you want the big lights to come on with.
I've always used the old school 6" KC offroaders and got the brightest bulb i could find.there bright as Hell and the do the job.they might be a little big though if your trying to put them behind your grill though
