Need help power steering
Old Nov 20, 2008 | 11:44 PM
Grey-Ghost's Avatar
Grey-Ghost
Exclamation Need help power steering
Ok i have a 2004 ram with the v6 and my power steering leaks no matter what i do i put lucas stop leak didn't help then when my coil pack when out at 46000 miles the shop messed with it and it was find now at 52000 miles its doing it again but worst moaning sometimes sounding like the trucks going to die and this is the second it happen and in the winter only my question is what can i do isthere a tsb on it or are we on are own and what have u done to fix it
Old Nov 21, 2008 | 06:37 AM
02Steve1990's Avatar
02Steve1990
same problem with me, this is the second time my psf is leaking (both during the cold season start up) I took my truck to the dealership the first time and they fixed it and I had no problems until now (which is about a year) so I will most likely end up bringing it back to the dealership. It also depends where its leaking from, for example if the leak was in the tube, then thats easier to fix than if the leak were in the pump
Old Nov 22, 2008 | 09:41 PM
Wanderer's Avatar
Wanderer
I had my high pressure hose replaced just short of 36,000 under warranty due to the crappy clamp on the hose. There are numerous threads on how many have replaced the clamp. Would lose very little PS fluid during the warm months and much more when it got cold. Just 2 weeks ago, I had to replace the PS cooler at 54K due to it rusting through. The dealer actually told me that 4 years in the northeast ain't bad.
