Look what I got today!!!
The more I drive it the more I love it! 93 tune is way better then the 91 tune on the SC. I have more power taking off and can really get it sideways. Takes alot to get these 22's to spin but not as hard now.
As far as MDS shut off, I went to a GTG today. It was 2 hours away and I could get 20 mpg on the highway before. Ended up getting 16.3 with no MDS and no farting backfiring sound. I am so glad I got this thing. Cant wait till the spring to bring it to the track and see what times I can run.
Finally got my Predator today. I plugged it in and got the message "predator u7137 does not support CALID 05094506AI."
Called customer support and they said that I need the patch cable to update the software. I simply figured a brand new programmer for a brand new pickup should probably work without an update!???
I found this:
What comes with the Kit? The PC Interface Kit contains a DiabloSport approved DB9 to DB9 serial extension cable and a 12 Volt 1 Amp power supply. You can also use your own cable and/or power supply, or buy them from other sources: *The cable is a standard (straight-through) serial cable, also called DB9 Male-Female cable or DB9 9-wire Serial Cable Extension. (Radio Shack part no: 26.117B) *In order to power the Predator up at your desk, you will also need a 12 Volt (1 Amp minimum) power supply. The plug tip is 2.5mm x 5.5mm, female, and center is positive. (Radio Shack part no: 273-1776)
pretty harsh comment. Most people including myself would expect a NEWLY RELEASED programmer to be most current. Why would you think otherwise? I understand there have been revisions, but the tuner should atleast be functional for the guy. Places are pushing those $2 a/c adapters and $5 ebay special USB wires for a profit. I would just wait and get them off ebay or go to radioshack.
I found this:
I found this:
With my predator I got the 2nd Prime delete. SCORE!
I already have apower supply and the cable off ebay is only $5
Also, I just purchased the Diablo Predator tuner from here for $325 shipped http://tunertools.com/proddetail.asp?prod=DS%2DU7137
How? Do they have an update for that already? Mike had said they hadn't even begun to program for that. That was just last week.
