rear differential problems
I bought a 2005 dodge ram 1500 4x4 back in maywith 20000 miles on it. when i first bought the truck the posi was working and a couple months ago it just quit working. i took it into the dodge dealership to get it checked out and they told me that my truck never had posi and i know it did. any ideas??
It may not have. In the right conditions, it will spin both tires without it.
Read here and submit your vin and ask for a build sheet.
https://dodgeforum.com/forum/3rd-gen-ram-tech/179642-build-sheet.html
Mine came back like this
3.92 Axle Ratio
Corporate 9.25 LD Rear Axle
Anti-Spin Differential Rear Axle
Anti-spin is the limited slip unit.
3.92 Axle Ratio
That might not be a bad thing if you have no stock LSD.
Just do a search on the dreaded retaining/c clip problems on these stock Dodge LSD's.
They are a NIGHTMARE!!!!!
If you havent got an LSD installed, consider buying a Detroit Trutrac or an Aurburn LSD.
That way, you will get a bullet proof LSD and not have to worry about the "grenade waiting to go off", that is the stock LSD that Dodge install.
Hope this helps?
Al.
