Magnaflow exhaust question
Old Nov 23, 2008 | 06:20 PM
Joey0480's Avatar
Joey0480
Default Magnaflow exhaust question
Going in Tues for my exhaust to be done on my 08 5.7.
Just a few questions before I go. I am most likely going with a magnaflow SI/DO (either both out the back *or* one on each side behind the wheels...not sure yet).
Anyways,
I am figuring on going 2 1/2 pipes out. Sounds right, right? And a 18 inch magnaflow what most of you are running?
As for the y-pipe.....I read that many people said that they are restrictivce. I am unsure how much this place would charge to change it around, but I am basically putting on my exhaust for look, sound, and mild performance gain/mpg gain....should I really consider looking at getting the y done?
thanks
Old Nov 23, 2008 | 08:05 PM
dirtydog's Avatar
dirtydog
Moderate User
The stock exhaust is 3". Just remember that if you have a place custom bend an exhaust you will only be getting mild steel vs the Stainless that came from the factory.
Old Nov 23, 2008 | 08:53 PM
Got_Hemi44's Avatar
Got_Hemi44
Anyways,
thanks
Straight 3" Stainless True Duals
Old Nov 23, 2008 | 08:59 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
I'd leave the Y-pipe alone...it'll be expensive to have tru-duals put in or a X/H pipe fabbed. And if you're going to do that you'll want two SI/SO mufflers.
Old Nov 23, 2008 | 09:02 PM
04 HEMI 04's Avatar
04 HEMI 04
i wouldnt do straight pipe. it just make LOUD noise. it does give less restriction but sounds of straight will be horrible on hemis
Old Nov 23, 2008 | 09:08 PM
mopardodge1500's Avatar
mopardodge1500
right now iv got dual 2 1/2" straight pipes, but plan on dual 4" straights
Old Nov 23, 2008 | 09:11 PM
Got_Hemi44's Avatar
Got_Hemi44
Exactly.... and they look sweet
Old Nov 23, 2008 | 11:15 PM
nickahern1's Avatar
nickahern1
dual 4" straight pipes?? thats huge. i would think that would be way to big and the engine would loose from that, having little to no back pressure at all. I may be wrong. but.....
i personally went with a single 3inch in to dual 2.5 out flowmaster 40 series. custom fab exiting out the sides behind the rear tires with 3inch slash cut tips. It sounds awesome and is very loud. alot of drone on the highway but i love it and also had the resonators removed. leave the y-pipe alone for now. maybe down the road if you want to get headers then get a high flow y-pipe with new cats and so on......
Old Nov 24, 2008 | 12:05 AM
dirtydog's Avatar
dirtydog
Moderate User
Well given that your initial pipe diameter is only 2-1/2" at the flages and then opens up to 3", 4" is a little extreme. Besides the bigger you go and the less restriction you have past a certain point significantly reduces low end torque! Sure you gain top end hp, but it's not worth the amount you will lose off the line which is where you are most of the time. The only reason guys at the track do huge exhausts and dumps is to keep the head ports cool at higher rpms and keep the flow up because at the track your engine is mainly running from 75%max rpms to max rpms.. Not a good idea to go 4" duals.
Old Nov 24, 2008 | 12:28 AM
mopardodge1500
so what would you say then 3" is a good choice, i would like a bit bigger then i already have
