So I guess Headers are out of the Question :(
#31
on
Headers are a piece of cake on the Hemi, do it yourself. Even though I welded mine, most headers now a days are bolt on (as are most after market exhausts).
You can get to EVERYTHING from underneath and inside the wheel wells with only having to remove the plastic well liners, tires can even stay on and actually make a nice little work bench.
I'd go for the ceramic coat, and not the cheesy factory one. Buy you headers in uncoated and unpainted stainless and find a good, local, reputable coating shop to coat them inside & out. If you don't know of a shop, ask the Harley owners, as they always know the chrome shops and most places that chrome plate also do ceramic coating. It only added about $125 to the cost of my LT's had I gotten them with the factory coat and the custom coat is 10x better. A few minutes after turning off the truck while the temp of my cats is still over 600 degrees, I can lay my hand on on the ceramic coated headers.
#32
if you go ahead with the install from JBA
consider doing a
before and after test
for free using
http://www.bgsoflex.com/dyno.html
consider doing a
for free using
#33
