Switching from Synthetic to Dino oil..
Old Nov 28, 2008 | 09:49 AM
JD1500's Avatar
JD1500
Default Switching from Synthetic to Dino oil..
Is there anything special you need to do when witching back from synthetic to dino oil? Or can i just drain and fill?
Old Nov 28, 2008 | 11:41 AM
nickahern1's Avatar
nickahern1
why are switching back from synth to dino anyways? you should be able to just drain and fill as if it wasa normal oil change.
Old Nov 28, 2008 | 12:00 PM
dirtydog's Avatar
dirtydog
Moderate User
It's just a Drain and Fill, but i gotta tell you....I went to synthetic after my first oil change and I think I'm gonna switch back. I have a lifetime warranty, so what's the point of spending all that money???? I'm really contemplating that! it's a point that another member brought up and makes complete sense to me. $30 vs $50 because the 5.7L oil capacity
Old Nov 28, 2008 | 12:09 PM
dirtydog's Avatar
dirtydog
Moderate User
Occasionally Advace Auto here in NY has the Mobil 1 special of 5qts and filter for $24.88, but then you still have to spend another $12 on 2 more qts.
Old Nov 28, 2008 | 12:23 PM
nickahern1's Avatar
nickahern1
walmart almost always has the 5 quart jugs of mobil-1 for under $30. i usually pay $40 to do an oil change for 6 quarts and a purolator pureone filter.if i buy the quarts all seperate its maybe a few bucks more. dino oil is half that to do a change (under $3 a quart) but with dino oil i would do it every 3k with synth i do it every 5000-7500. so if you add it up its about the same price in the end anyways. thats just my opinion.
Old Nov 28, 2008 | 01:31 PM
HammerZ71's Avatar
HammerZ71
Yea, I tend to agree with ****yhern, I use Royal Purple with a high quality (Wix, Mobil 1 or Purolator) filter and change it every 6k as opposed to every 3k, so the cost difference is really not a factor, plus I ain't gettin any younger so having to climb under and changing it half the time counts for something too...
Old Nov 29, 2008 | 10:40 PM
Wanderer's Avatar
Wanderer
I'm of the mind set of HammerZ71 using Amsoil. Besides the extended oil changes, I picked up some MPGs (well maybe a half), so over time it pays for itself. In the winter here in the northeast, there is a noticeable increase in cranking speed when it drops below freezing.
Old Nov 29, 2008 | 10:45 PM
SmokeySportRam's Avatar
SmokeySportRam
just keep it changed at 3k and youll be good to go on dino oil, thats my routine
Old Nov 29, 2008 | 10:52 PM
dazed01's Avatar
dazed01
The lifetime warranty isn't on wear, it's on defect. If your bearings wear out it don't look like it's covered. I just did my first oil change, my second is gonna be mobil1
