Body lift ????
Old Dec 2, 2008 | 07:07 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by txj
anyone ever install a BL without a level kit? I had to take my level kit out because of extreme 4x4 shudder. I hate the stock stance, but i thought if I could at least lift the truck it might look better. I did a quicky photo shop to see how it would look... not sure though. I might just have to save up for a full on suspension lift.
Yeah, you'll have no issues installing it, but because it lifts the whole truck a uniform 3", you'll still have that nose down, rake look after your done...
Old Dec 2, 2008 | 08:18 PM
TheBaker's Avatar
TheBaker
So if you have the frame mounting hitch, the hitch from the factory towing will be fine like normal after a body lift?
Old Dec 2, 2008 | 09:23 PM
HammerZ71's Avatar
HammerZ71
Yup, you just lose the option of slipping a ball in the hole in the bumper and towing something...
Old Dec 3, 2008 | 06:50 AM
txj's Avatar
txj
What about this: The hitch the dealer installed for me mounts in part to the frame, but there are also two bolts that mount to the bumper. the then installed a plastic cover on the bumper to cover the two bolts.
I take it I will need a new receiver installed?
Old Dec 3, 2008 | 07:40 AM
HammerZ71's Avatar
HammerZ71
It sounds like relocating the rear bumper may not be an issue with that setup, don't know. You could always just not use the bumper relocation parts and leave it. You basically will have a 3" gap tween the bottom of the tail gate and the bumper.
Shoot me a pick of that setup and I'll have a better idea what your working with...
Old Dec 3, 2008 | 07:55 AM
txj's Avatar
txj
will do. won't be until tomorrow most likely, as the truck is at the dealer right now... while they attempt, once again, to fix the 4x4 hi shudder problem.
thanks...
Old Dec 3, 2008 | 01:54 PM
RubberFrog's Avatar
RubberFrog
The PA kit includes the appropriate brackets for the factory hitch. Basically, it has a piece that bolts in between the hitch and the bumper, filling the gap. The hitch itself doesn't move.
Old Dec 3, 2008 | 01:58 PM
RubberFrog's Avatar
RubberFrog
Here is another body lift pic-
Old Dec 3, 2008 | 02:10 PM
DeaDinside's Avatar
DeaDinside
Nice TRUCK.!.!.!..is that a 3in body lift...and nothin else?
Old Dec 3, 2008 | 02:18 PM
RubberFrog's Avatar
RubberFrog
3" bl + 2" level up front on 35's
