Install on Auto Meter Oil Pressure Gauge
Old Dec 5, 2008 | 11:37 AM
DeaDinside's Avatar
DeaDinside
Default Install on Auto Meter Oil Pressure Gauge
Hey,
Has anyone hook-up a Auto Meter Oil Pressure Gauge (Mechanical)to a hemi...If so can you help me with the install..a website with pictures on How to and where it hooks-up to...or a step by step walk though of it...
Thanks
Old Dec 5, 2008 | 03:18 PM
dirtydog's Avatar
dirtydog
Moderate User
eeeeeek. Mechanical??? I wouldn't use anything other than an electric sending unit. Much cleaner, more reliable and no mess like mechanicals if the line brakes or the fitting swells up and contracts. I wouldn't recommend any mechanical guages.
Old Dec 5, 2008 | 10:23 PM
lxman1's Avatar
lxman1
Site Moderator
Mechanical is more accurate. They do not vary as the voltage changes or with a bad ground. I have never had a line leak or fail.
You need to make a T fitting to use the factory sending unit and the mechanical gauge. This will keep the PCM happy by seeing oil pressure thru the factory gauge.
