Mods No Good
Old Dec 7, 2008 | 11:47 PM
  #21
WeightLifter500's Avatar
WeightLifter500
Agreed with the gears. Dodge Nitto has about 6'' of lift and is running 37x13.5 mud grapplers and still manages 14mpg around town. I have talked to him quite a bit and his 4.56 gears were a great improvement after the lift that gave him better than stock power and MPG's. With a truck that is lifted 6'' tires that measure 37.1x14.3x20 he can out run his stock brethren's trucks. Pretty impressive that when adding that much size he can still out run a stock hemi. But I would suggest 4.56 gears with a detroit tru-trac for your truck. Probably would be your favorite mod after you felt the difference.
Old Dec 7, 2008 | 11:48 PM
  #22
minyo16's Avatar
minyo16
also if i get the 4.56 gears should i get the tru lock for it also? or is it just anothe way to wast gas?
Old Dec 7, 2008 | 11:50 PM
  #23
minyo16's Avatar
minyo16
Thanks sounds like i need to save up becuse i cant do something like that my self. any idea on how much laber might cost. like how long might it take time wise?
Old Dec 8, 2008 | 06:58 AM
  #24
kincer04hemi's Avatar
kincer04hemi
Anytime you do any mods engine or drivetrain wise you should reset the pcm afterwards. Even just a reset after a tuneup it helps a bit.
Old Dec 8, 2008 | 12:06 PM
  #25
minyo16's Avatar
minyo16
whats a pcm reset?
Old Dec 8, 2008 | 05:24 PM
  #26
kincer04hemi
On a 2004 you pull out fuse #23 under the hood , get in the truck turn the key to the start position and hold it there and you will hear a chime and the pcm is reset. Put fuse back in and your done. Pcm is the engine computer.
