Electrical question??
Old Dec 8, 2008 | 12:03 AM
dodgenitto's Avatar
dodgenitto
Default Electrical question about load resistors??
I already have load resistors installed in the wiring on my truck for my rear red leds. The new taillights I am looking to buy come with load resistors already installed in them! So would I have any problems having 2 load resistors for each side?? Or would one not effect the other??
Old Dec 8, 2008 | 12:13 AM
dirtydog's Avatar
dirtydog
Moderate User
As long as they are the same size resistors OR your current one's are bigger. If the one's you have are smaller, they may not work properly, but you can have 1,000 resistors of the same capacitance and it's the same as having 1 of the same size.
Old Dec 8, 2008 | 12:58 PM
bolang's Avatar
bolang
+1 as long as they are same size it won't make a diifference
Old Dec 8, 2008 | 07:31 PM
dodgenitto's Avatar
dodgenitto
bump to top
Old Dec 8, 2008 | 07:41 PM
sos's Avatar
sos
If the new ones come with resistors already installed, I'd take the old ones out and install the new lights as if you were replacing your OEM.
Old Dec 8, 2008 | 08:02 PM
dodgenitto's Avatar
dodgenitto
Yeah, I was hoping to avoid that! I spliced then into the wiring underneath the truck and screwed then to the back side of the bumper mount. It would just be a pain in the butt!
Old Dec 8, 2008 | 08:23 PM
sos's Avatar
sos
It might work, but you also might have a problem... Say for example that the load resistor is 1k ohm and so is your old one. Your truck is looking for 1k ohm, but now you have two resistors, which add up when in series, so now you have 2k ohm. This might make your turning signals blink too slowly, or cause the "check bulb" indicator to come on on your dash.
Old Dec 9, 2008 | 02:47 AM
abarmby's Avatar
abarmby
Wink
Huh?????
" but you can have 1,000 resistors of the same capacitance"
Resistors have.................well...................resist ance my friend.
Capacitors build up a charge and have "capacitance".
Wink wink.
Al.
