inside door cover
Old Dec 14, 2008 | 12:07 PM
bigboss's Avatar
bigboss
Default inside door cover
does any one have a scamatic on how to take the door cover off, my outside latch isnt working
Old Dec 14, 2008 | 12:20 PM
jmr's Avatar
jmr
There are I think 3 screws that hold it on and the door handle needs to be removed with a Torx 40 socket. Unplug the wires for the power switches then lift the panel vertically.
There is more info here....
https://dodgeforum.com/forum/3rd-gen...questions.html
Old Dec 14, 2008 | 04:13 PM
eaglestorm's Avatar
eaglestorm
there are 2 screws on the very bottom one behind the door handle and one at the upper corner if it's a ft door. the panel pulls up staight up the you can remove the wiring you can remove the window switches first but becareful not to brake the cover or scare the panel
