Problem w/ 3rd brake light?
Old Dec 15, 2008 | 10:45 PM
megablacktank's Avatar
megablacktank
Default Problem w/ 3rd brake light?
Alright here is the deal. I have a 3rd brake light from recon w/ l.e.d.s and have had it since 05'. It was in my 03' sigle cab dodge before but we decided to have a family so it had to go for more room(megacab). needless to say i kept the 3rd brake light put it on 07' truck. recently noticed within the past year that water has started to leak in thru the roof of the cab in the area were the 3rd brake light is. just checked to day on the recon home pg to make sure that there were no changes in the brake light. this light will fit from 03' to 08'. i think that the insulation may have a bad spot in it or is starting to wear out. now granted this light has been pulled of this truck several times thanks to my little bro wanting to try it out on his truck. here are some pictures and if anyone has an idea as to how to fix this problem i would greatly appreciate it. the stock light is back up for now. it does not leak. K there will be no pictures at this time. for some reason they won't load up.
