Hemi Hat
Old Dec 18, 2008 | 06:04 PM
04 HEMI 04's Avatar
04 HEMI 04
Default Hemi Hat
I have the afe cold air intake that is connected to the hemi hat and i was wondering that i want to get rid of hemi hat... but the only problem is that, if i got rid of the hemi hat, would i lose more mpg or not. How do you connect the tube to the throttle body? Would it help me gain more power and mpg? Would it void a warranty?
Any advice or comments would be greatly appreciated.
Old Dec 18, 2008 | 06:11 PM
nickahern1's Avatar
nickahern1
the hemi hat.air baffle is the biggest restriction within the stock intake. im not sure how your going to attach the original afe intake to the throttle body without it looking weird. you could probably find couplers to do it but i really do not think it would look good. maybe get rid of the afe( sell in classifieds)and start froms sratch,
i cannot promise youll see better mpgs and better power increase but i would think you would see gains in throttle response and minor hp/tq gains. usually trying to gain HP and mpgs at the same time is a conflict of interests. i did my intake/exhaust/programmer for hp/tq without caring of mpg gains but i also got my truck knowing it had a drinking problem too.
Old Dec 20, 2008 | 12:02 AM
04 HEMI 04's Avatar
04 HEMI 04
I just dont care about the looks. I do care about POWER. As u can see my truck look like plain stock.
Old Dec 20, 2008 | 01:18 AM
CreativeOffroad's Avatar
CreativeOffroad
Not trying to thread-jack or anything, but how do you like the aFe Stage II?
Old Dec 20, 2008 | 11:38 AM
04 HEMI 04's Avatar
04 HEMI 04
It is really good and very easy to install. It gave more power through rpm band and better throttle system. It made my flowmaster rumble much deeper. PLUS it has great looking. I dont have to oil them as i can wash them easily.
Old Dec 20, 2008 | 12:32 PM
ramhunter9's Avatar
ramhunter9
i just got a rubber cupler that came with my kit and i slid one end over the tb housing and conected the rest looks awesome . the only down side of it was i had to tap my own hole for the air sensor in to the pipe. but all is good with it.
Old Dec 20, 2008 | 02:04 PM
Ramdamit98's Avatar
Ramdamit98
http://store.summitracing.com/partde...5&autoview=sku
Airaid makes a modular tube that replaces the Hemi hat and clamps right onto the throttle body. Not sure if it'll work with the AFE, it hooks up to the stock air box.
Old Dec 20, 2008 | 06:25 PM
lxman1's Avatar
lxman1
Site Moderator
That's what I'm going to get after Christmas. The Airaid MIT and keep my stock box with K&N filter.
Old Dec 27, 2008 | 11:50 PM
04 HEMI 04's Avatar
04 HEMI 04
do you know how to take off the hemi hat and do you know what kind of tube i can connect the afe to the throttle body?
Old Dec 28, 2008 | 03:51 AM
Ramdamit98's Avatar
Ramdamit98
I'm assuming you have this intake
They make an aFe stage 2 that has a shorter tube than the Airaid one, but I haven't seen that piece sold by itself. This is another stage 2 that goes right to the throttle body with the shorter tube that I believe would fit your application if you could find the shorter tube.
As for the Hemi hat I believe there is just 2 10mm bolts, disconnect the IAT sensor and loosen the hose clamp to the flex hose/joint going to the air box/filter and pull the Heni hat out.
