Looing oil pressure
Old Dec 18, 2008 | 11:03 PM
ice-burg-slimm's Avatar
ice-burg-slimm
Default Looing oil pressure
I have a 03 1500 and today i lost oil reading on the guage.The truck is due for an oil change but the oil level on the dip stick was still good.I'm thinking i have a bad oil pump,but i want some opinions thanks.
Old Dec 18, 2008 | 11:12 PM
michael.watkins32's Avatar
michael.watkins32
Default it's not your pump
Usually it is the oil pressure sensor. It is on the oil filter housing. i would rec. starting there.
Old Dec 19, 2008 | 10:44 AM
ice-burg-slimm
Thanks i will start from there first,and i will keep you posted.
Old Dec 19, 2008 | 03:05 PM
HammerZ71's Avatar
HammerZ71
If you've got the 4.7, they are notorious for getting gummed up with sludge over time, causing oil not getting up where it needs to be. Drop the pan and have a look/see. Clean it out good and then a little Sea Foam treatment should do the trick.
MMStar23 had the issue and has quite the lengthy thread in this section detailing it and his fix a few months back. Do a search - good reading...
