Fluid level for differential
Old Dec 22, 2008 | 01:19 AM
Palm's Avatar
Palm
Default Fluid level for differential
I understand that there was a TSB out on the 9.25 axle, that called for different fluid levels. As I remember it, one series was supposed to be filled all the way to the bottom of the fill hole, and another was only to be filled to 1/4 inch below the hole. Does anyone remember this TSB, and how would I tell which one my truck has?
Old Dec 22, 2008 | 01:22 AM
Ridinhigh's Avatar
Ridinhigh
I just had mine done its an 04 like yours and my father who is the parts manager said they fill them up to the fill hole which is about 3/4 full i havent heard about having 2 different levels
Old Dec 22, 2008 | 03:54 AM
abarmby's Avatar
abarmby
I have read both of the fill capacities and am also unsure as to the correct levels?
One person even suggested that the overfilling to "just below the fill hole" would cause the pinion/seals to blow??
Al.
Old Dec 22, 2008 | 12:12 PM
dirtydog's Avatar
dirtydog
Moderate User
All rear fluid differentials should be filled 1/4-1/2" below the fill hole regardless of make or model.
