2005 RAM 1500 SLT CD player trouble
Old Jan 1, 2009 | 10:55 AM
Baker88's Avatar
Baker88
Exclamation 2005 RAM 1500 SLT CD player trouble
I have a 2005 RAM 1500 SLT and i recently tred to install a pioneer DEH-P6000UB cd player. I pluged it into the harness and nothing worked. I e installed the stock CD player and that wont work now. Also my alarm wont activate, my keyless entry and power locks only works when the truck is turned on or the key is in the ACC position. I have checked all the fuses under the hood and they all are fine and i hve run out of ideas. PLEASE HELP ME!!!!
Old Jan 1, 2009 | 12:12 PM
Baker88's Avatar
Baker88
Update: I discovered that there is power on the ignition switch wire and the illumanation wire in the stock harness but there is now power going through the 12V constant battery supply wire. My power locks and keyless entry will still only work if the truck is running or in ACC, however my alarm still dosent work and my remote start will still work. Could it be an Immobilation Bypass Module? If so, then how can i reset it or fix my problem?
