lift ?
Old Jan 1, 2009 | 07:11 PM
minyo16's Avatar
minyo16
is there a way to make the lift bigger? like if i put on diffrent shocks? or would i have to buy a new lift kit? trying to learn some things and thanks for all thge help and sry for the stupied ?
Old Jan 1, 2009 | 07:36 PM
HammerZ71's Avatar
HammerZ71
You basically have two choices, add a body lift (which will expose more of the frame and suspension) or pull off the suspension lift and get another. The Skyjacker is the only 6" lift for torsion bar 1500s that I've measured so far that is a true 6" and clears 37x12.5s on a 4.5" backspaced wheel without trimming. I know for a fact the Fabtech, Procomp & Superlifts do not. Not sure of any others...
Old Jan 1, 2009 | 07:57 PM
Got_Hemi44's Avatar
Got_Hemi44
I don't see how it's a 6" lift kit. Your truck should be sitting a lot higher. What brand lift is it?
This is 6" inches:
Old Jan 1, 2009 | 08:52 PM
CreativeOffroad's Avatar
CreativeOffroad
Either your lift is sagging ALOT or someone lied to you. That barely looks like a 4" lift. You should definitely be clearing 35's no problem.
Old Jan 1, 2009 | 10:53 PM
02Steve1990's Avatar
02Steve1990
i dont know man, that truck is about as high off the ground as mine and mine has no lift or cranked torsion bars
Old Jan 1, 2009 | 10:54 PM
4x4HemiFreak's Avatar
4x4HemiFreak
yea i was just at 4wheelparts when i bought my fabtech 6" lift and said dont go with the pro-comp because it doesnt give you the full lift on the dodge and the steering is messed up by the is no center on the steering wheel
Old Jan 1, 2009 | 10:58 PM
02Steve1990
minyo if i were you i would take that "lift" out and start fresh, get a 6" skyjacker or topguncustomz suspension lift, there are a number of other good name brands out there don't try to mess with coils or anything just start fresh with another lift, that's my opinion though.
Old Jan 8, 2009 | 07:22 PM
minyo16's Avatar
minyo16
i got my lift kit from topguncustomz put even if i take it off i dont think they will take it back. and it was a 6in pro comp. witch im pissed aboput they shouldnt be able to say it a 6in lift if its not
