auxiliary light switch
Old Jan 7, 2009 | 11:12 AM
ram-fjallasport's Avatar
ram-fjallasport
Default auxiliary light switch
hi
there is manny off you people out there that have mounted aux light on your RAM.
but is there anyone that have found a switch that fit into the spare location next to the seat heat switch?
there is room for the switc there, but is there any switch with the light making made to fit there?
Old Jan 7, 2009 | 01:45 PM
dirtydog's Avatar
dirtydog
Moderate User
I don't think so. Nothing factory if that's what you mean. better off cutting it out and throwing in an aftermarket one. I used the little square in the dash where your left knee is.
Old Jan 7, 2009 | 01:56 PM
ram-fjallasport
yea I have seen that manny do the cuting on the left side and so on..
but waht are the hole/space for then.. some extra equipment?
Old Jan 7, 2009 | 02:17 PM
SeMiGoD's Avatar
SeMiGoD
Check out this post...hopefully it helps you out a bit.
https://dodgeforum.com/forum/3rd-gen...ht-switch.html
Old Jan 7, 2009 | 02:28 PM
ram-fjallasport
Thanks semigod
that is close to what i am looking for..
I guess I am happy when I find the one that fit into the mid-console next to seat heater.
but your link was a good substitute.
Old Jan 7, 2009 | 05:20 PM
oefootball_70's Avatar
oefootball_70
Here are my three switches one for the cab lights
one for my lights behind the grill
One to start the truck
hope this helps!!
Old Jan 7, 2009 | 05:37 PM
ram-fjallasport
yea manny good idea's....
what about here
Thats what I want!
Old Jan 7, 2009 | 05:42 PM
SeMiGoD's Avatar
SeMiGoD
Dont see why you couldnt put it in there as long as you have the room to mount the switch and run the wires.
Old Jan 7, 2009 | 05:49 PM
ram-fjallasport
I was curious if there is any inthe same style as the original one...
I guess I just dont want to put that aftermarket switch in there!
Old Jan 7, 2009 | 05:50 PM
oefootball_70
what about here
Thats what I want!
You can put one where ever you can cut a hole and run the wires to it. just dont be cheap like me and use only one color wire. It will get confusing in the long run. All my switches are ran with white wire. It does get to be a little too much sometimes.
