Lowering the Ram
Old Jan 7, 2009 | 10:52 PM
fox_racer627's Avatar
fox_racer627
Default Lowering the Ram
Whats the lowest I can go with the stock 20's off of an 06 and 305/50-R20 tires without having to bag or c-notch. 2", 4.5"?
Old Jan 7, 2009 | 10:55 PM
RaiderJay6's Avatar
RaiderJay6
2x4 or 4x4?
Old Jan 7, 2009 | 10:56 PM
mdram43's Avatar
mdram43
http://www.lmctruck.com/ICATALOG/DE/full.aspx?Page=79
Old Jan 8, 2009 | 01:31 AM
chefred112's Avatar
chefred112
2/4 is the first level of drop but those tires are big for a drop...
Old Jan 8, 2009 | 08:31 AM
fox_racer627
it's a 2wd. The tires are brand new so it's gotta fit with them.
Old Jan 8, 2009 | 09:03 AM
lowgoat's Avatar
lowgoat
you might want to look into a leveling kit. But my friend has a 2/4 drop on his and he has 24"s on it and the top of the tire sits level with the fender. If your worried about the tire rubbing just look at it and see if it will clear the fender with full suspension travel the front shouldnt be a problem. I had a 4" drop in the front of mine with 22's and it didnt rub the frame.
Old Jan 8, 2009 | 12:28 PM
dirtydog's Avatar
dirtydog
Moderate User
Throw them in the garbage. My tires had 1200 miles on them and I put new one's on. Those HO's suck in the rain, they are too soft, puncture easy, they are terrible around corners and they have no traction what so ever.
Old Jan 8, 2009 | 01:45 PM
fox_racer627
Yea they do suck in the rain but they're better than the toyo proxes sts I had before. I already have 2" drop shackles so it's level but I think a 2 4 kit would b good.
Old Jan 8, 2009 | 04:31 PM
nickahern1's Avatar
nickahern1
why did you get such large tire if you were planning to drop your truck. isnt that like a 33.5 inch tire?? i would have gotten a lower profile tire if i was planning to drop. a 2-4 is probably the lowest you can go with tall tires. they also make 4-6 and even lower drops if you want. check out slammed1 suspensions. they make great products for the ram.
Old Jan 8, 2009 | 05:02 PM
nim81's Avatar
nim81
get some 17" rims and low pros and you probably go alot lower.
