Leak around Oil Pan?
Hi Guys, Love this forum. I have a 2002 Dodge Ram 1500. I had leak at the clamp on the power steering last week that I fixed. Now I noticed that when the truck is parked after being driven that I have some sort of leak that appears to be coming from around the oil pan. Almost looks like it is coming from seal but not sure. It doesn't seem to be oil that is leaking, but a brownish green fluid. I am taking it to the shop tomorrow but hoped one of you had had a similar experience that might give me a clue as to what I am dealing with before the dealership tries to rip me off. Thanks!!
Power wash the residue off the the botton of the engine and frame and watch. Hopefully its only coolant that (1) came from the overflow and mixed with the grime on the underside off your truck (2) you have a loose or defective hose and and again its blowing back or (3) your radiator is shot which is not uncommon on a 6-7 year old truck.
Since the color tells us its coolant, a presure test at your local service station should be able to identify any leaks. Check the simple items frist, after all, maybe your're ride is caughting a cold, alot of that is going around
