06 hemi - abs disabled
Old Jan 11, 2009 | 03:18 PM
droby's Avatar
droby
Default 06 hemi - abs disabled
Hello everybody!
I own a used dodge ram big horn 5,7 hemi. My truck hasn't abs. I don't know why, is it possible the first owner has disabled it ? how to restore it?
No abs light is on.
Thank you, regards.
Old Jan 11, 2009 | 03:20 PM
CarGuyOhio's Avatar
CarGuyOhio
I you do not have a ABS light on, and it does lite when you turn the key on, that indicates it is working. Chances are you only have back ABS and not 4 wheel ABS, fairly standard with Rams.
Old Jan 11, 2009 | 03:21 PM
dodgeorgethit's Avatar
dodgeorgethit
My 06 has rears only..have yet to have them work
Old Jan 11, 2009 | 03:54 PM
droby's Avatar
droby
I don't feel on my feet the usual vibration on the brake pedal...that was why I think I do not have ABs...I was on ice and my truck was slipping straight when I pressed the brake pedal. It wear m+s tires.
Old Jan 11, 2009 | 03:59 PM
dodgeorgethit
Mine does the same......
But then if you lock all four on ice your truck just thinks you stopped........
Old Jan 11, 2009 | 06:29 PM
young-gun's Avatar
young-gun
Yeah, if you dont have the traction control package, you dont have 4wheel abs...the rear wheel abs is pretty much close to useless in my opinion.
Old Jan 11, 2009 | 06:30 PM
lxman1's Avatar
lxman1
Site Moderator
Rear abs only unless it is a Laramie, they have 4 wheel abs. Something finally fixed in 09, now all have 4wheel abs.
Old Jan 11, 2009 | 08:45 PM
InfernoRedHemi's Avatar
InfernoRedHemi
I have felt the rear abs on my 08 when braking on ice. I had to hit them hard.
Old Jan 11, 2009 | 08:48 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Originally Posted by droby
Hello everybody!
No abs light is on.
Thank you, regards.
Like the others said you only have rear ABS because it was standard...4 wheel ABS was an option.
Keeping the rear from coming around on you is useless? Hmmm..
Old Jan 11, 2009 | 11:30 PM
nh5's Avatar
nh5
How can I check if my 02 has 4wheel ABS?
