I Painted My Headlights...
Old Jan 11, 2009 | 10:45 PM
WhiteBerry's Avatar
WhiteBerry
looks sick!
Old Jan 11, 2009 | 10:58 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Looks good. Did you use the technique where you put the headlights into the oven to heat them up and soften the glue? I have heard a lot of guys do it that way and was curious if you used the same method.
Old Jan 11, 2009 | 11:02 PM
6 hemi ram's Avatar
6 hemi ram
very nice. really adds to the look.
Old Jan 12, 2009 | 11:43 AM
TANKZ400's Avatar
TANKZ400
As soon as I get a day of bored um I am definitely going to paint mine.
Old Jan 12, 2009 | 10:48 PM
Alpheus's Avatar
Alpheus
I used duplicolor the same same code as my truck. I used the method that was posted on here I think, were I put them in the oven to heat them up to soften the glue and it worked perfect. the scotch brite works realy well for taking off the chrome. The only problem I ran into was taking the tape off the chrome. It tends to stick too well and peeled a little bit of the chrome off. I even used the expensive low adhesive painters tape and chilled them in the freezer to aid in the release. Also use a very soft cloth when cleaning the chrome before you reassemble the lights. I used paper towels and windex and it scratched the chrome. As for inspection, I have my old lights that I can throw on for a day for that...
Old Jan 12, 2009 | 10:57 PM
Alpheus's Avatar
Alpheus
PS.
I kept all the old sealant on the headlights and put them in the oven to heat up the glue and put them back together when they were hot with a set of ratchet straps. I did not have to add any silicone at all and they are perfectly sealed...
Old Jan 12, 2009 | 10:59 PM
nim81's Avatar
nim81
looks great alpheus
im gunna paint mine black when i find some cheapo's and have the whole black on white thing goin on.
Old Jan 13, 2009 | 08:22 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Originally Posted by ried69
Omg, some of you guys suck. There's only so much that I can want to do. I'd like to paint my lights too. Was it hard to paint them? Also, not to sound mean or rude or offensive, but does it take much skill or patience to paint them? Or is it mostly just using a fine brush to brush it on in small amounts to be sure not to have runs? And they look really good. Have any closer pictures of just one?
That looks GREAT. I colored matched mine too, alst fall. left the reflector in though. Its a stock look, but looks so much better.
ried, it's easy to do. look up the DIYs in that section. use duplicolor rattle cans, the color matches pretty well, I got the same color truck as you. And it being behind a lens hides small mistakes you make pretty well. does take some patience, not much.
Old Jan 13, 2009 | 11:12 AM
muns152000's Avatar
muns152000
SICK MAN that is very nice
Old Jan 13, 2009 | 01:48 PM
oefootball_70's Avatar
oefootball_70
since you bought an extra set. What are you doing with your now extra set?
