06 ram HID flashing installation problem
Old Jan 11, 2009 | 10:47 PM
badblackram06's Avatar
badblackram06
Default 06 ram HID flashing installation problem
Hello all. i purchased a H13-3 HID conversion kit for my 06 ram. I ran into something very odd when i installed them. i hooked them up like the instructions said. they come on but as soon as i crank the truck they start flashing a few times then shut off. They also flash when i turn them on while the vehicle is running. i swapped the high beam wire with the low beam wire and they stay on when the truck is running but the high and low beam are reversed. so low beam is actually high beam and high beam is low beam, if that makes any sense. I want to hook them up right so what do i need to keep them from flashing?
The flashing has caused one bulb to malfuction. It no longer switches beams and is now stuck on low beam.
Old Jan 19, 2009 | 10:58 PM
badblackram06
wow this forum wasnt as much help as they say it was going to be. thanks!
Old Jan 19, 2009 | 11:05 PM
ried69's Avatar
ried69
Way to have some patience there buddy. There are several threads about this, so many of the people get tired of replying to these same questions over and over again, especially to new people. Ever notice the amount of threads in a day? It's also hard to notice every single post. But try the search button to see what answers you can find. Also, someone told me about a capacitor for newer vehicles for their HIDs to get rid of the flicker, and they are $40 for two.
Old Jan 19, 2009 | 11:07 PM
RaiderJay6's Avatar
RaiderJay6
Thats a very common problem with some no-name HID kits. The Dodge computer senses that there is no bulb because the HID's have less resistance then halogens. The flashing is the computer sending pulses to the lights to check to see if they are there. You are going to need resistors to get them to work right.
Old Jan 21, 2009 | 11:04 PM
badblackram06
Ah ok thank you. where can i get these resistors? and how much would i expect to pay. Sorry for being impatient
Old Jan 21, 2009 | 11:26 PM
ried69's Avatar
ried69
With what the site says, these should be the same thing as the resistors.
http://www.stealthauto.com/Products/...__HID-CAP.aspx
And don't worry about impatience, it's hard to notice some threads sometimes, so a little bump to the top works just fine. Just have to have someone notice it.
Old Jan 21, 2009 | 11:33 PM
dirtydog's Avatar
dirtydog
Moderate User
Capacitors are NOT the same thing as resistors! 2 different things.
He needs capacitors not resistors. The capacitors soak up all of the power and distribute it evenly to make the light not flicker. A 470uf capacitor is what you need. That will be large enough to hold the voltage being sent and keep the bulbs from flickering. You'll need 2 and wire accordingly. I would just buy pre-made one's with directions if you haven't a clue.
Old Jan 21, 2009 | 11:38 PM
SeMiGoD's Avatar
SeMiGoD
RaiderJay bought a "seamless" kit that installed and worked without messing around. Ask him what he got and maybe you can return the POS ya bought and buy what Jay did to begin with.
ried69's Avatar
ried69
I don't know a whole lot of that, but in my defence, Jay is the one that said resistors, and I said capacitors. However, I have to thank Kindschi for that link to the capacitors. He showed me the link to those particular ones.
Old Jan 21, 2009 | 11:52 PM
RaiderJay6's Avatar
RaiderJay6
I never had to mess with this. I have read several posts with people having problems buying products that are supposed to work on all vehicles. Dodges are not like all vehicles. I would return the kit and if you need a plug and play kit PM me and I will give you the contact info on a simple and great set.
