well they fit
Old Jan 12, 2009 | 06:33 PM
grap660's Avatar
grap660
Default well they fit
okay im selling my 88 ford bronco and it has 33 size tire with 15in rims well they are brand new to came with the bronco when i bought it in augest but then my parents bought me my ram as a early hs grad present im wonder if they well fit my 04 dodge ram because im gonna lift it in the summer and if the tires well fit then i well save money they are bfg tires
Old Jan 12, 2009 | 06:49 PM
SeMiGoD's Avatar
SeMiGoD
If im not mistaken on 04 the smallest tire size is 16 inch due to the calipers.
Old Jan 12, 2009 | 07:06 PM
HemiNow?'s Avatar
HemiNow?
If they do fit with the caliper issue i think you will still need a 2" or 21/2" leveling kit. I have 33's on my truck and had to lift the front .
Old Jan 12, 2009 | 07:17 PM
grap660's Avatar
grap660
im gonna do a 4 inch cst suspension lift on my truck
Old Jan 12, 2009 | 07:49 PM
red06RAM's Avatar
red06RAM
I believe the smallest wheel for ALL 3rd gen rams is 17.
Old Jan 12, 2009 | 07:50 PM
nickahern1's Avatar
nickahern1
no you cannot fit them on your truck at all. smallest you can go is 17s. ive seen peopel grind the calipers to fit 16s in the past but wouldnt reccomend it.
Old Jan 12, 2009 | 07:52 PM
Twink's Avatar
Twink
You wont fit anything under a 17"
Old Jan 12, 2009 | 08:12 PM
grap660's Avatar
grap660
ok then i well just leave them on my bronco then but would 20 inch rims from an aspen fit on my ram and what do you guys think is better lifting my truck yup or just put 20s on and work on the inside
Old Jan 12, 2009 | 08:14 PM
lxman1's Avatar
lxman1
Site Moderator
20's and the inside.
Old Jan 12, 2009 | 08:36 PM
draco8494's Avatar
draco8494
well if its 4wd lift it and put all terrains/ mud terrains (whatever you like) if its 2wd then put 20"s and do the inside, or level it with 2 1/2" spacers up front and still put the 33"s on it and use the money you saved on the 4" lift kit and do the inside?
