Truck Shuddering
Hey guys. Been a while since I've been on here. Had a problem pop up with my Ram and I thought I'd come here lookin for answers and suggestions. So here it is. Basically as I accelerate thru and decelerate thru roughly 40-45 mph, my truck shudders until I get out of that range. I thought it was the rotors but I replaced those and the brake pads. I'm wondering if maybe my suspsension is loose at some point. But its makin me kinda nervous. Any ideas guys?
sounds ball joint'ish to me, raise a side up and look for excessive play... Other factors could make for this though can be as simple as a tire out of balance or a driveshaft out balance...
Shutters and vibrations are just a big PIA the isolate. Usually easy to fix when you find out the cause, but a bi*ch finding the culprit most of the time...
ya know...this question has poped up a few times before. I also have the same issue with mine. vibe between 38-42mph. I think there is more to it than tires. so far thats the usual answer that comes from the thread. believe me its been to a few shops and ive bought new tires new wheels new ball joints new shocks all new brakes and even had the stealership replace the whole rear end(c clip club). and i still have the vibration. hope someone has an answer for it someday. it seems kinda wierd that this many of us have the same issue around the same mph. any help would be great.
Also, if you did not have your tires "road force" balanced, you threw your money away and the issue still may be tire balance...
U-joint's? My truck needed them @ 48k. They don't have to be loose to be bad,they can bind up due to being dry and cause a vibration.
Trending Topics
That's why I said this, but if you are going to start someplace, the tires are the easiest & cheapest to check. Plus are the culprit a fair majority of the time...
IM not saying its not the tires. at least i hope it isnt. I used to have BF at's. had em balanced about 3 different times by the dealership.then bought the pro comp at's at good year and had em mounted. went back to have em balanced again, twice and still had the vibe. so i bought new rims because they said it may be the wheels.( the old ones were Fugly anyways) so the new tires with less than 500 miles were mounted/balanced on new rims. between rims and tires its been some serious money outa pocket! but no matter what they have done that stinkin vibe is till there between 38-42mph.........man i hope it isnt the tires, those things are getting expensive! hey hammer I've been meaning to tell you that your truck is sweet!
But it's amazing how many times guy take it in and have them balanced, rotated, etc. Eventually finding out in the long run it WAS the tires. Was just a guy here not long back bought a set, vibrations from hell, had 'em balanced, rotated, everything. Every place swore it couldn't be the tires, swapped them out for another set (same brand, different size) and the problem was gone! Now that ain't saying it's the tires for sure, I've seen an out of balance drive shaft do it too! Usually ball joints aren't speed specific issues, but not always. Like I said, a vibration is the biggest bi*ch to isolate the cause of!!!
