clad take off
Old Jan 20, 2009 | 09:56 PM
ramhunter9's Avatar
ramhunter9
Default clad take off
how do you take off the hub cap thingy cover on the stock ram rim????
Old Jan 20, 2009 | 10:26 PM
sos's Avatar
sos
I assume you mean the chrome clad cover... I believe it's glued on. It might come off with force, but you never know what it will look like under there.
Old Jan 20, 2009 | 10:49 PM
CarGuyOhio's Avatar
CarGuyOhio
Ugly. I saw a Ram with one that was cracked. Leave them on, unless you are replacing them.
Old Jan 20, 2009 | 11:27 PM
InfernoRedHemi's Avatar
InfernoRedHemi
Do you think that underneath the clad cover would clean up and smooth out or is it something that is beyond a polishing?
Old Jan 20, 2009 | 11:34 PM
SeMiGoD's Avatar
SeMiGoD
If nothing else, bead blast it and clear it or paint it.
Old Jan 21, 2009 | 09:14 AM
ramhunter9's Avatar
ramhunter9
reason i ask is because i want to paint them but dont know if paint will hold on the plastic clad that is smooth chrome
Old Jan 21, 2009 | 10:45 AM
dirtydog's Avatar
dirtydog
Moderate User
Underneath is rough, far away from a polishing. It's a rough cast that has some lines through out. The paint will stick much better to the properly prepared plastic than to the wheel itself.
Also, the plastic cap doesn't heat up like the wheel itself does from heavy braking, therefore the paint won't get soft and prone to chips or peeling like if it were on the actual rim itself.
Old Jan 21, 2009 | 08:14 PM
ramhunter9's Avatar
ramhunter9
dog would you say painting the clads is a easy job that will come out nice??
Old Jan 21, 2009 | 08:30 PM
HammerZ71's Avatar
HammerZ71
Rule of thumb - If it's easy to do, it won't come out nice!!!
Old Jan 24, 2009 | 09:39 PM
mongospaz's Avatar
mongospaz
Has any one tried to remove a clad cover yet? I would also like to remove them to paint them and try to reinstall them. I was bummed out to find out they are plastic and not a solid aluminum rim.
