Torsion Bars
Old Jan 22, 2009 | 09:53 AM
02Steve1990's Avatar
02Steve1990
lol yeah i'm just cranking them im so pissed I ran around town for like 30 minutes haha..what should I use to crank them?
Old Jan 22, 2009 | 09:54 AM
rebel61021's Avatar
rebel61021
you only need the tool for removing and replacing them if you are just going to crank on them you dont need it, I would have a good breaker bar or an air inpact gun becasue they will be hard to turn. and probally spray them real good with wd-40 would help also.
HammerZ71's Avatar
HammerZ71
It would be called a socket set... with all the weight off the front end, they'll go pretty easy once you break 'em... You need to not cheat on this, measure both sides from tire top to wheel well (on level ground), lift the truck and turn each side a couple cranks, then drop the truck, measure and raise it and adjust. You may need to raise & lower it a couple times and don't assume that the same number of cranks gives the same results on each side - don't know why, but it's like that and why you have to measure...
And don't forget the alignment...
Old Jan 22, 2009 | 09:57 AM
rebel61021's Avatar
rebel61021
also don't know if this is allways true but we ran mine up about an inch over level becasue was told after driving around it will settle down a little mine came down about 3/4 of an inch over the next month. Now she looks real good.
Old Jan 22, 2009 | 10:00 AM
02Steve1990
lol alright I'm gonna go give this a shot
Old Jan 22, 2009 | 10:05 AM
rebel61021's Avatar
rebel61021
makes sure you get some before and after pictures.
dodgeorgethit's Avatar
dodgeorgethit
what year di they go to springs?
or is it just on 2x?
Old Jan 22, 2009 | 10:23 AM
02Steve1990
definitely
Old Jan 22, 2009 | 10:29 AM
HammerZ71's Avatar
HammerZ71
all 3rd gen 4x2s have coils and 06+ 4x4's. The "free" lift option is only available to '02='05 1500 4x4 owners...
Old Jan 22, 2009 | 12:54 PM
JoeHemi's Avatar
JoeHemi
so...will replacing the front shocks for longer shocks be necessesary if the torsion bars are cranked to level?
