Torsion Bars
Old Jan 22, 2009 | 07:40 AM
02Steve1990's Avatar
02Steve1990
Default Torsion Bars
Hey guys, not really good with my knowledge on the torsion bars, can somebody tell me where they are located, I'm looking to give myself a little lift in the front and how do I crank them up?
Thanks
Old Jan 22, 2009 | 07:57 AM
HammerZ71's Avatar
HammerZ71
Piece of cake. This is the first illustration I found, but it is the same on your truck.
You'll find the "torsion keys" at the front end of the bars. Under each key is a bolt that is perpendicular to the ground. These are the bolts you crank.
Old Jan 22, 2009 | 08:15 AM
02Steve1990
should I use a jack to get the truck off the ground a bit or is that not needed? BTW can you repost that image Hammer? I tried refreshing the page a bunch of times but for some reason it doesn't want to show up.
Thanks
Old Jan 22, 2009 | 08:48 AM
02Steve1990
Actually I went and took a look under the truck and I think I found them so I took a pic just to make sure..
I was looking more towards the front wheels I had no idea they were in the middle of the truck
Old Jan 22, 2009 | 08:51 AM
rebel61021's Avatar
rebel61021
here are some pics of when I changed the keys on mine to lift the front end up to level. Was alot easier than I thought as long as you have the torsion bar tool to crank on the keys with.
Here is the old Key next to the new one.
here is the bolt that you crank in to lift the front end just remeber the more you crank it in the stiffer the front will ride. also make sure you do both sides the same and measure from the bottom of the rim to the bottom of the wheel Well.
You can see the bolt head just sticking out from the cross member that holds the key.
Here she is before the lift
and after the lift
Here is a link to my smugmug pictures af all the work that has been done so far to my truck. http://stuckey.smugmug.com/gallery/4...60945149_enmRs
Old Jan 22, 2009 | 08:52 AM
BEAR's Avatar
BEAR
yep thats them, here is a link that I used when I was looking to do mine. It explains it completely step by step https://dodgeforum.com/forum/3rd-gen...on-friday.html
Old Jan 22, 2009 | 09:01 AM
02Steve1990
Thanks for the help guys I appreciate it, I'm gonna head over to pepboys and see if I can rent a torsion bar tool from them for a bit
HammerZ71's Avatar
HammerZ71
Yep, those are the ones, and yes unless you got gorilla arms, you are going to want to raise the front enough to get the weight off the tires...
Old Jan 22, 2009 | 09:48 AM
02Steve1990
Alright well I went to pepboys, monroe, goodyear, and advanced auto and none of them have a torsion bar tool, not sure what i should do now or is there something else I can use?
Old Jan 22, 2009 | 09:51 AM
HammerZ71's Avatar
HammerZ71
I don't understand, you are only cranking the bolts, right? Why would you need the tool? You only should need the tool if you are replacing the keys!!! And my local Advance has the the tool, rented it when I did the keys on a buddies '02 RCSB 5.9 4x4...
