Pro Comp vs. TGC Leveling Kit
So, I have been looking at the TGC leveling kit for some time now. Last night, I was using the search function (yes, i just said search) to find info on bakes that I have to change this weekend and found out that the pro comp leveling kit is better because it has the stock shock extenders instead of over extending the stockers. the pro comp is a little more, but to me it just sound better. what do you all think?
my shocks didnt really extend all that much. im not really worried about it. the ride didnt change at all either. i am however going to get new shock soon anyways just cause if eel like doing it all this spring/summer. upgrade to somenice billsteins or something probably. i have the 2.5 inch tgc kit and love it. very easy install too.
also, do you have a 1500 or a 2500?? just wounderin, i got a 2500 and the TGC leveling kit, went in pretty nice, and i have a write up of it on here somewhere, and i also havent felt any change in the ride..and im also going to put some new shocks on whenever i get some money
or this only possible on the 4x4 models?
Trending Topics
$48.95 for 1.5" coil spacers.
2wd has front coil springs
i got the 2.5 tgc kit. installed myself in a few hours. its very easy. then got an alignment right after i was done. at first the 2.5 was a little too high in front then it settled and its now perfect. if you have decent mechanical and car knowhow you can do this yourself and save the money you were goign to spend to have someone else do it. to make it even easier have a buddy help you. it shouldnt take more than 3 hours to do the install. the directions that come are pretty good. the only thing you need to knwo is watch out for the brake lines/speedo sensor on driver side when lowering and taking out strut assembly as you dont want to break it or stretch it too far. good luck if you need any help let me know. i can guide you through it without even seeing what your doing haha. its that easy.
for your 06-08 1500 4x4s get the steel spacers not the daystar or similar spring spacers. the spring spacers arent as fun to install because you need to rent a spring compressor and take apart the strut assembly to install. with the steel spacers you dont need the spring compressor at all, the whole strut assembly comes out as one peice and then goes right back in. im not sure for you 02-05 guys. not familar with your setups i know they are torsion bars and you can crank them up for free or get torsion keys.
