Pro Comp vs. TGC Leveling Kit
Old Jan 24, 2009 | 01:12 AM
nim81's Avatar
nim81
Originally Posted by nickahern1
for your 06-08 1500 4x4s get the steel spacers not the daystar or similar spring spacers. the spring spacers arent as fun to install because you need to rent a spring compressor and take apart the strut assembly to install. with the steel spacers you dont need the spring compressor at all, the whole strut assembly comes out as one peice and then goes right back in. im not sure for you 02-05 guys. not familar with your setups i know they are torsion bars and you can crank them up for free or get torsion keys.
you could always use heavy duty ratchet straps to compress the springs. works for me and youve probably got one layin around soewhere
Old Jan 24, 2009 | 01:23 AM
nickahern1's Avatar
nickahern1
yeah you could do that too. but its just easier to get the spacers that sit on top of the assembly all together. better install. seriously it will take you double the time to do the first wheel than it will to do the 2nd one. i forgot to mention the tools required
BEER!
standard/metric ratchet set and wrench set
2 jack stands
floor jack
a nice drop light helps.
a hammer
loctite
BEER!
Old Jan 27, 2009 | 02:26 PM
caliboy@heart's Avatar
caliboy@heart
so i started the post and now i cant find the pro comp kit that comes with the sock extenders. WTH! anyone know where i can find it on line again?
Old Jan 27, 2009 | 06:22 PM
caliboy@heart
if i can find the pro comp kit with the shock extenders i will buy it tonight.....i just ordered tires.
Old Jan 27, 2009 | 06:31 PM
caliboy@heart
so i know why i cant find them.......they weren't pro comp they were a kit from fatbobsgarage.com. what do you all think about this kit? here is the link:
http://store.fatbobsgarage.com/share...t=products.asp
