surging engine with heater on...normal?
Old Jan 25, 2009 | 09:05 PM
Romeosoldier03's Avatar
Romeosoldier03
Default surging engine with heater on...normal?
if Im ideling and the heater is on then the engine revs like from 500-700 up and down...if i shut it off then the surging stops...is this normal.....114,000 miles and still tickin
Old Jan 25, 2009 | 09:23 PM
Romeosoldier03
anyone?
Old Jan 25, 2009 | 11:00 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Do you have a lot of electrical accessories on your truck?
Old Jan 26, 2009 | 09:00 AM
Rojhan's Avatar
Rojhan
Pop the hood and see if your A/C is kicking in. The system might be calling for "defrost" when in heat, or an electrical issue could be making it run. The A/C sucks quite a bit of power and can make your RPMs drift.
Old Jan 26, 2009 | 09:21 AM
HammerZ71's Avatar
HammerZ71
when you are turning your heater on, are you also using defrost? The defroster will cause the A/C compressor to kick on, engaging the aux. fan as well. The PCM will therefore boost idle to assure you will not stall...
Old Jan 26, 2009 | 06:48 PM
lxman1's Avatar
lxman1
Site Moderator
Any position to the right of the floor symbol will activate the a/c compressor.
Old Jan 26, 2009 | 09:57 PM
Off_Road_Teacher
It sounds electrical. When I first hooked up my e-fan I had it running on the high speed motor and when I would run the fan, my heater blower, head lights and fog lights all at the same time I would get a little surge like you are describing.
