Just Got My Ported Throttle Body Today!
Old Jan 26, 2009 | 08:34 PM
RaiderJay6's Avatar
RaiderJay6
Originally Posted by 0SO
I would also like to know if its honed all the way through or just tapered the front and back.
It is tapered its starts at 85mm and tapers down to 80mm at the butterfly.
Old Jan 26, 2009 | 08:38 PM
dirtydog's Avatar
dirtydog
Moderate User
The most that can be done is taper the opening. The butterfly plate has to close. If more material was taken out, a new, bigger buterfly plate would need to be used.
I did this on my mustang T/B. The only thing it added was touchiness to the gas pedal. If the oening is say 75mm, only 75mm of air can squeeze through that hole. Tapering both sides doesn't allow more air to go through. Tapering helps the initial throttle respone and that's it.
A bigger T/B is the only way to gain hp. Even then, the engine must want the airflow. Some cars only gain minimal on T/B swaps and others can gain 20hp like S/C'ed engines.
Old Jan 26, 2009 | 08:39 PM
RaiderJay6's Avatar
RaiderJay6
I think i want one will this make me run 12s in the 1/4?
You can only run 12's if you have the Tornado in your intake.
Old Jan 26, 2009 | 08:41 PM
OSO's Avatar
OSO
I have another tb here think i will just have it worked on . Has any seen how far they can go with it +90 ?
Old Jan 26, 2009 | 09:54 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I am jealous, I want one of those tb's. The guys that already have them have been reporting good results with these ported tb's.
