Code from my truck P0405 ....sighhh
Old Feb 11, 2022 | 09:20 PM
Derek Mason's Avatar
Derek Mason
Originally Posted by Daniel Zukowski
I have a 2007 Chrysler Aspen 5.7 Hemi, I had a code P0406 and was told to replace the EGR Valve on it which I did, now the check engine light is back on on with code P0405 (Exhaust Gas Recirculation Sensor A Circuit Low). I was reading through this post but I don't see a PCM fuse on my Aspen available to reset the PCM. I've reset the code numerous times with a code reader to no avail, it keeps coming back, the last thing I did was removed the + and - battery cables and tied them together for 30 minutes to discharge all the electronic charge in the electrical component capacitors and such. I've heard this some times works. Has anyone seen this issue on an Aspen or similar and if so how was it resolved?
I'm having same issue but it's not drivable electronic throttle control light flashes and I have no throttle response. Did you ever find a fix for your issue???
