aftermarket lugs
Old Jan 26, 2009 | 11:49 PM
SeMiGoD's Avatar
SeMiGoD
Originally Posted by nim81
yes that would suck, i would only use one as a last ditch effort, but this is what i was reffering to
http://www.amazon.com/Power-Wrench-Telescoping-handle-extension/dp/B000A8N5GI/ref=sr_1_6?ie=UTF8&s=automotive&qid=1233029953&sr= 1-6
works great
and was way cheaper at wal*mart
Neat tool but that wont solve his problem. He explained it to be, between the wall of the lug ports on the rims and the lug nuts themselves, there isnt the room for a socket to actually fit in there to tighten the lugs. My rims wont work with regular lugs either. There isnt enough space to insert the socket. Thats where the spline style lug comes in.
irelandshemi's Avatar
irelandshemi
yeah im just looking to get them on not planning on taking them on and off all the time i just cant tighten them enough to drive with them with a regular socket
Old Jan 26, 2009 | 11:54 PM
SeMiGoD's Avatar
SeMiGoD
Thats the whole point of the spline...when you NEED to remove them, flat or replacing tires...if they were on for a prolonged time, you will break that thin wall socket and be screwed. Good luck with that. Ive seen it happen before and its a nightmare to get around.
Old Jan 27, 2009 | 12:05 AM
irelandshemi
can you send me a link to a picture of the socket for the spline socket i guess i dont know what the inside of the socket looks like, o and i got the enkei solars, 300$ couldnt pass it up
Old Jan 27, 2009 | 12:09 AM
irelandshemi
nevermind found a picture of it, is it easy to get another wrench in case the one gets lost or do you have to order it
Old Jan 27, 2009 | 12:50 AM
SeMiGoD's Avatar
SeMiGoD
Im not really sure. I assume youd have to order 1 but dont hold me to that. I simply keep mine in my glovebox so i always know where it is and its always in the truck.
Old Jan 27, 2009 | 12:53 AM
irelandshemi
sorry for all the questions just never really looked into them, can they fit into a small area like the thinwall can as far as between my lug and rim?
Old Jan 27, 2009 | 01:03 AM
SeMiGoD's Avatar
SeMiGoD
Thats what they are made for. If you look at the pattern on the lugs, they are intented. Thats the type of lug i had to go with. I had the same issue on my rims as you are seeing with yours. Its the solution to your problem...a safe 1. I ordered mine for 36 bucks shipped about 1.5 years ago. Got em less than a week. Return the lugs you bought and use the $ for the spline type.
Get ahold of this guy info@wheeldiscounters.com his name is Andy. Tell him your year ram and you need the spline style lug.
Old Jan 27, 2009 | 01:30 AM
irelandshemi
thats what ill end up doing then, it came out to just under 50 for mine, i was just hoping to avoid having to wait my brothers girlfriends mom isnt too happy about a bunch of tires in her garage but ill just tell her shes got a little while longer
