CB radios
Old Jan 27, 2009 | 08:14 PM
Bruce_County_Boy's Avatar
Bruce_County_Boy
Default CB radios
hey guys and gals i have searched this forum up and down and havent found the information i am after.
i have a 2004 ram 1500 slt with a 5 speed stick and a floor mounted 4x4 shifter and am kinda in a dilemma as where to mount my cb , truck is a regular cab if this helps and pictures would help alot as well
Old Jan 27, 2009 | 08:24 PM
yhike's Avatar
yhike
I have the Cobra 75 WX ST. what I like about its small and moves easy from Jeep to the truck and I can put it up when I don't need it.
Old Jan 27, 2009 | 08:28 PM
06CountryBoy5.7's Avatar
06CountryBoy5.7
tot he right of the center console is where i would put mine. Mounted nice and flush. dont have pic but look at your truck and you will see
Old Jan 27, 2009 | 08:38 PM
HighDuke1911's Avatar
HighDuke1911
I remember a thread where someone placed it where the cupholders are. Maybe you can stick it there as well. I would also consider under your driver's seat and have the walky-talky part hooked somewhere near your radio. Maybe the wire would be long enough for that and to reach your face as well. I hope that helped somewhat.
Old Jan 27, 2009 | 09:28 PM
Redone4x4's Avatar
Redone4x4
You would want it somewhere you can see it and reach it while youre driving...depending on what kind you have. I have a cobra 29WXNW and cant find a good enough spot yet for it...
Old Jan 27, 2009 | 10:08 PM
Ram4wd's Avatar
Ram4wd
I have a small Cobra CB, but not like yhike mentioned, mine is just a smaller standard box unit. Its a 19DX III; I think. I have it mounted on a 'Seat Bolt" flex mount off of the Drivers seat and positioned between the drop down cup holders and center front seat area. It works, but isn't an absolutely solid mount and might not be good for a heavier unit.
You can find a similar flex mount if you search for Arkon mounts; though several other companies offer equivalent mounts. You might also check out the following site and then search for "CB Mounts".
He has two plate mounts that mount under and forward of the center seat/console area. I am considering upgrading to one of these two; either the wide or narrow styles.
Here is the link:
http://www.genosgarage.com/
Good luck, this is not a simple task in these newer Rams!
Old Jan 28, 2009 | 11:59 AM
Claw's Avatar
Claw
I don't know what the dash is like on your '04, but for my '06 I got a Cobra 18, which has a front-firing speaker. I was able to mount it in one of the open spaces in my dash underneath the factory radio.
Like yhike, I have the Cobra 75 in my Jeep, and it works pretty well also. I got an external speaker for it though, because the internal one isn't so great.
Old Jan 28, 2009 | 07:12 PM
6 hemi ram's Avatar
6 hemi ram
ditto on that. heres a pic.
Old Jan 29, 2009 | 02:21 PM
Hemipwr07's Avatar
Hemipwr07
mines a lil bigger..cobra 29 ltd. i put it right beside me between my seat and the middle seat. just wedged it in there. works great
Old Jan 29, 2009 | 05:18 PM
TANKZ400's Avatar
TANKZ400
What is the advantage of having a cb just to mess around with?
