4 or 6 inch lift.... Driveshaft?
what would be a 35" tire for 18" wheels? these are the wheels I am thinking about getting would these look ok on my truck with the backspacing bolt pattern and everything? (what is the 1500 5 lug bolt pattern) I like the super finish black wheels. I just want to make sure they wont stick out TOO far.... http://www.aewheel.com/wheels_detail_specs.cfm?id=363
if you have the stock twenty's the backspacing is 5.85. so that means that those wheels are gonna stick out about 1.35 farther. thats the look i was going for though.
bolt pattern is 5x5.5. and if you are looking at wider tires you are gonna have to go with a backspacing like you are looking at,or they will rub at full lock.
look at this chart. i was looking for a better one but this is the best i could find quickly. there are a few tire charts out there if you search.
http://www.dickcepek.com/MC_Radial.html
no problem. just make sure you pay attention to all the sizing on the side of the tire when you buy them. like 305 70 18 is a 35, and a 305 60 18 is a 33. it took me about 2 weeks to finally decide on a the right tire with alot of research.
heres the tire i finally purchased.
http://www.dickcepek.com/images/Crusher_Radial.jpg
and my rim. had my mind made up on it for a long time.
http://www.dickcepek.com/images/DC1_BlackLg.jpg
like i said havent got them on the truck yet,but they sure look badazz setting there. hope they look good when they are actually on the truck.
This is the lift I would like to go with. I'm pretty sure it should fit the '08. It's the only lift I've been able to find for the '08 other than a leveling kit.
http://www.gorancho.com/products/sus...am1500_4wd.php
These are the rims. I plan on going with 35x12.50 Pro Comp X-Treme ATs.
http://www.4wheelparts.com/Wheels/He...fPHE7917955212
This set up should work right?
on
My only issue with the Pro Comps is most guys I know have really bi*ched about keeping tread on the highway, really wear fast... But a good tire when it has tread...
