No Cluster Bus Error
Old Jan 29, 2009 | 12:19 AM
mattchiro's Avatar
mattchiro
Default No Cluster Bus Error
Its either a fried cluster or bad pcm in my '03 5.7. I've replaced the alternator and battery and all of the connections are good.
I'm still getting spikes and lows on the voltage gauge. Can a bad PCM cause this?
Old Jan 29, 2009 | 12:30 AM
yhike's Avatar
yhike
You may got another bad alternator it does happen. Have you check cable running down to the starter?
Old Jan 29, 2009 | 02:42 AM
OlDirtyJohn's Avatar
OlDirtyJohn
ive had a couple of experiences with bad PCMs on dodges. usually it will say "NO BUS" in your odometer area with a bad PCM
