anti-spin?
Old Feb 23, 2005 | 03:01 AM
gamagatsu1's Avatar
gamagatsu1
Default anti-spin?
is the anti-spin option a locking diff? I dont have it, but thinking of getting a locking rear diff. if i dont have it.
Old Feb 23, 2005 | 06:29 AM
Red Ram Hemi 2005's Avatar
Red Ram Hemi 2005
Default RE: anti-spin?
Anti spin is more like a limited slip.
Old Feb 23, 2005 | 10:45 AM
moparturd's Avatar
moparturd
It allows the wheels to turn at different rates when turning. A locker, true locker, doesn't do that.
Old Feb 23, 2005 | 12:07 PM
shortbus's Avatar
shortbus
ORIGINAL: mopartodd
Should also add that a true locker, in unexperienced hands will put you in a ditch on a wet road quickstyle.
Old Feb 23, 2005 | 12:13 PM
horatio102's Avatar
horatio102
Not really true on either of the last two posts. I true locker will allow the outside tire to spin faster than the inside while going around corners so long as you aren't applying too much torque to it. A spool, on the other hand, doesn't allow any difference at all between the driven tires, it creates understeer, it will chirp/squeal a tire around the corner, and could put you in the ditch. Same goes for welded spider gears (lincoln locker, etc).
Old Feb 23, 2005 | 02:14 PM
moparturd's Avatar
moparturd
That's right. Once again, I'm confusing my rearend with a hole on the ground. Spool, locker. Anti-spin, LSD, are the most forgiving on the road.
Old Feb 23, 2005 | 03:45 PM
gamagatsu1's Avatar
gamagatsu1
Thanks, I know enough about them that they should only be used in dirt or slippery surface's
Old Feb 24, 2005 | 06:27 AM
Red Ram Hemi 2005
That all depends on the locker you are using. There are lockers that will do that and some that wont. You need to know what you are buying and putting in your truck, and understand what it can and cant do.
