has anyone used an ebay intake???
Old Feb 5, 2009 | 07:21 PM
bkettering74's Avatar
bkettering74
Question has anyone used an ebay intake???
i have been looking for an intake for my truck that wasn't so overpriced, anybody use this one yet?
http://cgi.ebay.com/ebaymotors/04-08...spagenameZWDVW
i have a 2006 RAM 1500 5.7L HEMI quad cab Sport
Old Feb 5, 2009 | 07:22 PM
06CountryBoy5.7's Avatar
06CountryBoy5.7
looks cheap you get what you pay for. The only ebay intake I have heard that is a decent product is the spectre. Its on there for about $160.00 i believe
Old Feb 5, 2009 | 07:32 PM
bkettering74
Now I will admit I am new to the mod game. Correct me if I am wrong, intakes just look like basic tubing and an air filter. So what really is the difference between the intakes that cost 400 bucks and this one?
Old Feb 5, 2009 | 07:36 PM
06CountryBoy5.7
thickness/durability of the metal, quality of the couplings. Placement of the filter. all CAI run within the a simliar CFM from what i have found withing 100-200 CFM. buy the looks of that intake the angle and placement of the first rubber joint is weak and almost at 90 degrees. not as efficiant as many others. The filter is also very small compared to most other systems for our trucks and it has no heat shield. So cold air intake it really is not....more like hot air intake with a crappy design small filter thin tubing. get what you pay for
Old Feb 5, 2009 | 07:38 PM
06CountryBoy5.7
also the that filter location is prone to sucking up water and hydrolocking your motor
Old Feb 5, 2009 | 07:39 PM
ramhunter9's Avatar
ramhunter9
you can get that one but just put a k&n on the end it should be ok but like stated you get what you pay for
Old Feb 5, 2009 | 08:36 PM
Zed's Avatar
Zed
I Think I would make my own before I even considered that pos.
Old Feb 5, 2009 | 08:37 PM
bkettering74
has anyone had any luck with home made intakes with a good filter? if so any pics?
Old Feb 5, 2009 | 08:38 PM
TRXHemi's Avatar
TRXHemi
I used one at first but then modified it using PVC .....I replaced the filter with a real K&N and put it a little farther down behind the headlight where the jet stream scoop fed air directly to it. I love it. And it didn't cost an arm and a leg...
Check out the pics:
Before:
Then after:
Old Feb 5, 2009 | 10:39 PM
Redone4x4's Avatar
Redone4x4
out of curiousity, what did you do with your old one? I like the piping with the blue clamps personally. just asking, sorry for hijacking...lol.
