programmer question
Old Feb 6, 2009 | 08:56 PM
  #31
ramhunter9's Avatar
ramhunter9
we are in sooooo much trouble
DUDE SORRY TO HI-JACK THIS THREAD hammer made us do it
Old Feb 6, 2009 | 09:46 PM
  #32
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
awwwww my post got deleted...ahahha
Old Feb 6, 2009 | 09:48 PM
  #33
HammerZ71's Avatar
HammerZ71
customer complaints...
  #34
ramhunter9's Avatar
ramhunter9
ya mine to hammer is droppin bombs
Old Feb 6, 2009 | 09:53 PM
  #35
SeVeReDiStOrTiOn
Oh sorry...it was all in good fun
Old Feb 6, 2009 | 11:17 PM
  #36
HammerZ71's Avatar
HammerZ71
no biggie, but there be kiddies on here at times.... gotta keep it to at least PG13....
Old Feb 7, 2009 | 01:12 AM
  #37
rebel61021's Avatar
rebel61021
can I ask 1 dumb question??? what is MDS I have tried looking it up but can't find it.
Old Feb 7, 2009 | 08:05 AM
  #38
HammerZ71's Avatar
HammerZ71
Dodge’s Multi-Displacement System (MDS) shuts down four cylinders under light engine loads to conserve fuel.
Oh and btw: our '04s ain't got it, it's an '06+ 1500 thing...
Old Feb 7, 2009 | 08:43 AM
  #39
rebel61021's Avatar
rebel61021
Thanks Hammer
Old Feb 7, 2009 | 09:00 AM
  #40
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Originally Posted by trax
now theres an explanation i could have used in the first place!
true dodge didnt design the engine to run on that but they designed the truck or what ever term you want to use to run on 89. my original statement was that dodge designed what ever you want to call it the truck or the engine to run on 89 why would you put in anything more expensive? and what does a tuner other then change timing of fuel and ignition do?
sorry about the ignorism i was on the wrong track
well, at least you straightened yourself up and started learnin instead of tellin what you think you know. btw, you should have left your other posts so others could learn too, i know you're trying to save the embarrasment, but still. you got quoted on every one anyway, so its ok.
now to your question (and bringing this thread back on track).
the ONLY reason to use higher octane fuel is to avoid detonation, and don't let anyone tell you otherwise. some say that 'premium' fuel has more detergents than regular and stuff like that, but usually that's not the case, and even if it is, it's a side benefit and not worth the extra money.
so the only reason you would use a higher than recommended octane is if you either have detonation problems (it's hot and you're towing, you got carbon buildup...etc), or you did something to cause detonation. advancing timing can cause detonation, certain tweaking of A/F ratio can cause detonation. incidently, advancing timing also gives you more power. so advance timing, get more power, and band-aid the detonation with higher octane fuel.
the last two months have been great for dodge tuners and tuner updates. when the predator got released, it had a lot more options than the superchips. now superchips is countering with updates to add most of those options (if not all). the competition is really driving both to do everything they can:
you can adjust shift points, change transmission line pressure to make your shifts faster and firmer, disable mds, adjust tire size, gear size, max rpm before a shift at WOT...it just keeps going.
