Loss of engine control on highway
Old Feb 9, 2009 | 08:30 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Sounds like your truck is going into limp mode. Are you getting any codes?
Old Feb 9, 2009 | 08:44 AM
HammerZ71's Avatar
HammerZ71
Powertrain related, probably PCM. Good news is you should have a 7/70 Powertrain Warranty, let the dealer fix it...
Old Feb 9, 2009 | 01:10 PM
Lewie_North's Avatar
Lewie_North
Sucks because im not getting any codes... Nothing at all...
Old Feb 9, 2009 | 01:39 PM
dirtydog's Avatar
dirtydog
Moderate User
Yeah, then the Dealership will say nothing is wrong with it..lol
They can probably re-install the ecu programming. That may be all you need?? They will do a scan for codes, do a running diagnosis while on the lift and then reprogram your ecu and check again.
Old Feb 9, 2009 | 02:20 PM
irelandshemi's Avatar
irelandshemi
mine wouldnt rev wouldnt let me go above 2000 and slowly went down from there till i pulled over
Old Feb 9, 2009 | 03:54 PM
hemiguy0302's Avatar
hemiguy0302
drive by wire accelerator pedal fault is sorta what it sounds like to me. So it faults out trips up the computer which puts the truck into limp mode untill the condition is resolved. This has happened to me with the only exception being that it was a diesel truck that had the throttle fault.
Old Feb 9, 2009 | 04:23 PM
Off_Road_Teacher
Can't understand how dealers say that there is nothing wrong just because there is no code even when it is obvious something is very wrong. That one always puzzled me.
Old Feb 9, 2009 | 04:53 PM
dirtydog's Avatar
dirtydog
Moderate User
codes=quick solve technique
Problem solving outside the box= very costly. Unwanted
Warranty=low paid times quotes which don't even count initial time forth for diagnosis. Therefore, you get the old routine..."We found nothing wrong"...hehehe
Old Feb 9, 2009 | 05:06 PM
HammerZ71's Avatar
HammerZ71
That's what I'm thinking 'dog, but he's getting a code, if he's getting the dread "lightening bolt" it's recorded to the PCM and can be pulled. Hopefully a re-flash will fix, but with the code, he may have luck getting a new PCM under warranty of the flash don't cut it...
Old Feb 9, 2009 | 05:07 PM
hemiguy0302
dealership warranty work = greasy
