Replacing the 4.7L with a Hemi?
I'm sure it's been discussed before but I'm looking for a more definitive answer than I can find. I'm wanting to basically replace my 4.7L with a 5.7L Hemi. I want to find a short block and put comp cams and P&P heads on.
Does the motor bolt right up to the trans or will it need a different bellhousing?
I know it will need a Hemi ECM but how much of the wiring harness will need to be changed out?
How bad will this build be for towing wise if I have a good tune? I'm also contemplating a torque converter. Would that be bad also? I'm guessing so.
Anyways, I'm sure I have a million questions, but that's a start.
set aside 2-3k for the swap and that's doing all the work on your own and a slightly used engine. You will more then likely have to upgrade the tranny when you get a chance. It will bolt right on from my understanding. There is a gentleman who did a 4.7l swap from his dakota to a hemi. He had a hell of a time with the wires though; I saw pics and it was massive wires everywhere lol.
He has a yellow dakota and he did all the work himself. I dont remember if he has a dodgeforum account or another one where I read it. You best bet is to get in touch with him and he will square you away.
That sounds like a better idea. If you are going to go through all that trouble you might as well make it worth your while and drop something bigger in there.
Trending Topics
im going to be doing the hemi swap in my dakota with in the next few weeks. looking for the same info.
this is what i know. they use the same transmission as hemi rams, so they bolt right up. you will need to modify your oil pan to clear the cross member, and form what ie ead its not a terrible job wiring in the harness. even tho im trying to use a complete ram harness
