Another Programmer Question
wot stands for wide open throttle, basically when u slam the gas pedal all the way to the floor. Raising the shift points does just that, it raises the rpm's the truck will shift at. Changing the idle will change the rpm's the engine idles at. Not too sure when u would need this, i guess if u were to put a bigger cam in u might want to raise the idle a bit so it doesn't "lope" as much. I have the predator tuner installed in my 07 ram and haven't touched any of these adjustments, just installed the performance tune and she runs awesome with no mds
i have my truck tuned with 91 tune (running 93 octane cause 91 isnt available in my area)
rev limit is set to 6000
speed limiter is maxed out to 140 ( i dont ever plan to go that fast just did it so i had no limits)
1-2 wot is set to 5800 ( Wide Open Throttle shift point for 1st to 2nd gear)
2-3 wot is set to 5750 ( Wide Open Throttle Shift point for 2nd to 3rd gear)
ive tried the shift points maxed out and alot of different setpoints in between stock-max and ive found what i have it set on now to be the best for my truck.changing the wot shift points just lets you hold 1-2 and 2-3 a little longer than stock making you faster than stock when at wide open throttle from a stop. hopefully soon superchips will give us teh part throttle shift points as they have been talking about forever.
