i was so happy now im so sad
Old Feb 13, 2009 | 08:09 PM
  #21
Off_Road_Teacher's Avatar
Off_Road_Teacher
Whew, that is a lot of data that you can log on that thing. Wish I could get all that kind of data on my SC.
Old Feb 14, 2009 | 11:30 AM
  #22
Ram_It!'s Avatar
Ram_It!
here you go off road teacher,
cooling
amb temp
amb temp
amb temp ave
amb temp v
cat temp
ect
ect
ect v
exh temp
in man air temp
in man gas temp
oil temp calc
cylinder
tcyl ve mod
electrical
batt v
batt v filt
batt v scaled
O2s 11 def goal v
O2s 12 goal v
O2s 21 def goal v
O2s 22 goal v
oil press v
tps 1 min v
tps 1 v
tps 2 min v
tps 2 v
tps calc v to be continued......
Old Feb 14, 2009 | 11:46 AM
  #23
Ram_It!'s Avatar
Ram_It!
emissions
egr exh temp
egr flow
egr mass flow
egr pratio
egr sonic flow
exh press
in man egr mass
engine
engine runtime
oil press
ignition
base spk
spk adv1
intake
02 htr sns
02 htr11 ref v
02 htr11 sns v
02 htr11 sns v
02 htr11 temp
02 htr12 ref v
02 htr 12 temp
02 htr 21 ref v
02 htr 21 sns v
02 htr 21 temp
02 htr22 sns v
02 htr22 temp
baro
gas mass in manifold
iac tot airflow
intk temp
intk temp v
maf
map
map bs
o2s 11 goal v
o2s 11 sns v
o2s 21 goal v
o2s 21 sns v
miscellaneous
1/1 long term adap
1/1 short term adap
2/1 long term adap
2/1 short term adap
acc port mass flow
adap 11 fact
adap 21 fact
baro mult
base ve bank1
base ve bank2
desired fa cyl1
gasflow map
iac current
map v
map vac
misfire cnt
o2s 12 adap
o2s 22 adap
open loop fa
p-rat map baro
pcv mass flow
phi adap
phi mult
port pgr flow bank1
port pgr flow bank2
prg vac
purge af
read map kpa
read tip kpa
tcyl
tot port mass flow sca
tot port prg flow
total ve bank1
total ve bank2
veh spd mphx2
veh spd x64
to be continued
Old Feb 14, 2009 | 11:55 AM
  #24
Ram_It!'s Avatar
Ram_It!
misfire
knk fuel retard
knk lt retart
knk sns 1v
knk sns 2v
knk st retard
performance
eng rpm
eng spd raw
eng trq rfe
eng trq rle
rpm
trq act
veh spd
veh speed
throttle
acc pdl pos
base idle spd
thr angle
thr blade
thr pos%
thr pos v
transmission
trans oil temp
whew my fingers hurt but thats all of em, just dont ask me what any of it is lol
Old Feb 14, 2009 | 11:59 AM
  #25
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
yea there's a lot
Old Feb 14, 2009 | 01:04 PM
  #26
lxman1's Avatar
lxman1
Site Moderator
It's worth the money just for the data reading/scan tool. The added power is just a bonus
